Author Topic: AD19 - Not fitted components are not X-out on PCB  (Read 2199 times)
Offline d-chrisTopic starter
« on: January 25, 2019, 07:49:35 am »
i generated a variant and also imported it into the PCB document.
in the schematic the not fitted parts are marked but not in the pcb.
how do i enable draft-mode?
Offline twistedresistor
Re: AD19 - Not fitted components are not X-out on PCB
« Reply #1 on: February 11, 2019, 06:41:51 am »
fist, enable the variant in the PCB view via the dropdown menu. You can check if the component disappears in 3D view. Just to be sure the variant works.
I'm using AD 17, the component does not disappear or change appearance in normal 2D view, it only applies when you generate an "Assembly Drawing" output via an output job.
Make sure to enable the desired variant in the OutJob as well.
I can't check right now, but think it also does not change appearance in an "Composit Print"
