Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Wrong simulation results
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Wrong simulation results (Read 5024 times)
David_R
Newbie
Country:
on:
March 28, 2016, 03:59:20 am »
Hello, I'm trying to simulate a very simple LC circuit, with some initial conditions [ Vc1(0)=1V , Vc2(0)=4V ] but the results seems to be wrong
This is the circuit
those are the results
I was expecting to get the ideal behavior of an LC oscillator, someone knows which is the mistake?
Those are the handmade results:
Logged
amspire
Super Contributor
Country:
Re: Wrong simulation results
Reply #1 on:
March 28, 2016, 05:16:49 am »
Looks like the initial conditions were ignored and 1.5V was used across the capacitors instead. Perhaps the simulation couldn't cope with the lossless resonant LC circuit properly. You could add a small series resistor in the circuit - like 0.00001 ohms - just to see if it makes a difference.
Logged
David_R
Newbie
Country:
Reply #2 on:
March 28, 2016, 05:54:36 am »
I tried already with a 1u ohm resistor but it didn't work, I don't know if it just happens with my altium version
Logged
amspire
Super Contributor
Country:
Reply #3 on:
March 28, 2016, 06:28:33 am »
There is one more possibility. The circuit should ring with a 3V peak-to-peak sinewave or in other words, a 1.5V peak sinewave.
If the plot for some weird reason is showing AC Peak voltage for the two lower curves, then those plots are correct.
That still leaves the question about the zero amps in the top graph.
Logged
owiecc
Frequent Contributor
Country:
Reply #4 on:
March 28, 2016, 07:44:44 am »
I think this is due to how the circuit is solved. Try with more realistic parameter values or play with simulation parameters (increase step size, integration method). Maybe the default values do not work well with unrealistically high component values.
Logged
David_R
Newbie
Country:
Reply #5 on:
March 28, 2016, 04:53:11 pm »
But the results of simulation should be similar to the theory, so I think that no matter the values the simulation, it may work, one question, when you simulate the circuit on your computer, do you get the same result?
Last Edit: March 28, 2016, 05:00:02 pm by David_R
Logged
BMF
Contributor
Reply #6 on:
March 28, 2016, 06:09:24 pm »
What is the resistance of the inductor?
Logged
David_R
Newbie
Country:
Reply #7 on:
March 28, 2016, 06:27:17 pm »
It is an ideal inductor, you can find it in Miscellaneous Devices, it doesn't have an .mdl file or spice model
Logged
Fgrir
Regular Contributor
Country:
Reply #8 on:
March 29, 2016, 03:09:59 pm »
Try removing the "F" from the capacitor values - it seems like Altium is treating them as a femto suffix.
Last Edit: March 29, 2016, 03:26:39 pm by Fgrir
Logged
David_R
David_R
Newbie
Country:
Reply #9 on:
March 30, 2016, 05:26:09 am »
Fgrir thank you so much, finally it works
How did you find out?
Last Edit: March 30, 2016, 05:40:12 am by David_R
Logged
Fgrir
Regular Contributor
Country:
Reply #10 on:
March 30, 2016, 02:52:08 pm »
Glad I could help.
Quote from: David_R on March 30, 2016, 05:26:09 am
I think I've been burned by that same issue before - I vaguely remember spending an afternoon troubleshooting a simulation that had an ISRC set to 2A.
I haven't really used the simulator since I upgraded to Altium from Protel so trying out your circuit seemed like a good way to see what had changed. Setting initial conditions is one thing that has changed so it took me a little time to figure that out. Once I got everything set I got the same result as you so I tried a simpler circuit with just one cap and a resistor, and that simulation made it pretty clear that the capacitor was not 4F, but actually 4fF
Logged
David_R
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
