For everyone's sake (including your own in the future!), please learn how to draw schematics:
http://seventransistorlabs.com/tmoranwms/Elec_Circuit_Rules.html(Written specifically for the manual graphic method, but applies in general to all things.)
You appear to be trying to join pins with net labels, which is ugly. It completely breaks flow and leaves the reader wondering what possible signals might be connected. If drawing a wire is inconvenient, your circuit is presented -- move parts around until signals flow from left to right (preferred, with right to left as a second choice, usually for feedback signals that logically go back to the input side of things), and supplies flow from top to bottom (positive to negative).
Altium's auto label positioning is okay, but labels can be moved for better management of space or visual balance.
If you have many connections, they can be grouped in a bus; see the Altium docs on how to do this.
If you find you still have hanging connections (or it is impossible to avoid them, e.g., making connections between sheets), try Off-Sheet Connectors instead. (Don't use ports, those are for hierarchical blocks.)
Also, if you find you have many repeating circuits, consider using hierarchical design methods. Again, see Altium docs.
You also have GND symbols peppered around liberally, on wires that are all connected. This is redundant, not to mention ugly and confusing. A single connection only needs one net label, ever, and more than one produces a net naming conflict (check the Messages design workspace panel).
Regarding PCB transfer: if you don't have any footprints assigned (or they can't be found in the path), nothing will appear on the PCB to assign nets to. Check the complete list of ECO items to see which are going wrong.
