Author Topic: Global Net Settings in Altium ???  (Read 1583 times)
Offline IamSynthetiCTopic starter
  • Country: gr
  • White Smoke Activist
« on: October 22, 2020, 09:26:31 am »
Greetings,
I am new to Altium Designer and i am still trying to learn it. I am trying to change the track widts and lenghts of the some nets coming out of an IC. I am not sure, but i believe i saw a feature on OrCAD where there is a list of all the nets and you can make such changes there. Is there a similar feature in Altium ?
Thanks
Online T3sl4co1l
    • Seven Transistor Labs
Re: Global Net Settings in Altium ???
« Reply #1 on: October 22, 2020, 09:42:42 am »
Better, I'd dare say.  Probably OrCAD has this too, I don't recall?
Anyway, best way is to apply a net class to the nets in question.  This is done on the schematic.  On the PCB, create a rule for objects in that class.  Can even specify some rules from the SCH.
Next option is to call out the nets individually (with a query like "InNet('MyNet1') OR InNet('MyNet2') OR ..."), but this sucks as net names can change more often, or accidentally.  Especially if referencing auto-named nets.
There are also associations with components, pads, or rooms, which may be helpful.
Seven Transistor Labs, LLC
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: October 25, 2020, 03:38:16 pm »
in shcematic : place - pcb directive .
