Author Topic: How to move pins between subparts?  (Read 1811 times)
Offline Robert.AdamsTopic starter
  • Automotive Hardware Engineer
« on: April 23, 2015, 01:57:30 am »
Hello All,
I'm using a micro from the provided Altium libraries (Atmel ARM) and I'm trying to figure out how to move the VDDOUT pin with some other power pins (VDDOUT is on subpart 2 while the other pins are on subpart 3).  Whenever I click the edit pins button on subpart 2 and reassign the pin, it goes to subpart 3 but the text is invisible!  I haven't found a combination of send to back/bring to front that fixes this.
I'm using Altium Designer 15.  Help?
Offline DerekG
  • Country: nf
Re: How to move pins between subparts?
« Reply #1 on: April 23, 2015, 02:33:32 am »
You need to modify this back in the library. Best to save your modified component with a slightly different name & leave the standard library part unchanged.
I also sat between Elvis & Bigfoot on the UFO.
