Author Topic: Learning Altium - Multiple Schematic Sheets  (Read 4569 times)
Offline PoeTopic starter
« on: June 20, 2013, 07:00:35 pm »
I'm designing a two PCB device where the PCBs are soldered together with board to board header.  I have one PCB file for both boards, but a unique schematic sheet for each PCB.
I use unique net labels so the ERC does not claim I have an unrouted net between the two boards.
e.g.
"3.3V.a" vs "3.3V.b"
"MISO.a" vs "MISO.b"
It's messy and there's probably a simpler/cleaner way?
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Learning Altium - Multiple Schematic Sheets
« Reply #1 on: June 20, 2013, 08:13:18 pm »
Whats blocking you from creating two pcb projects?
« Reply #2 on: June 20, 2013, 10:30:42 pm »
I would like only one set of gerbers.  Is there an easy way to do that with two PCB projects?
