I've made some custom pads to better match a manufacturers recommended land pattern.
Every thing is fine unless the pad has no net,
Altium will then report a short circuit between 'pad on top layer and region on top layer'. (see attached image).
I've followed free_electrons advice
here Invoking "Design -> Netlist -> Update Free Primitives From Component Pads..." works,
the regions are assigned the same net as the pads, "No Net".....
so the violation is still valid.
I've tried allowing short-circuits between 'No Net' and 'No Net', (see attached image)
I've also tried Non-Specific No ERC directives in the schematic, (see attached image)
any ideas on how to get around this without assign names nets to every unused pin?
thanks so much for reading!
