Author Topic: Altium rooms broken??  (Read 282 times)
Offline axemaster
« on: July 14, 2020, 12:46:47 am »
I have encountered a bizarre situation in a multi-channel design. Whenever I drag a room around, none of the components move with it. It's as if they didn't belong to the room at all. However, if I tell the room to do "orthogonal fit" around the components, it correctly wraps around the components.
I have also discovered that trying to copy room formats is failing, again it seems not to recognize the components inside the room.
Has anyone encountered something like this?
Offline axemaster
Re: Altium rooms broken??
« Reply #1 on: July 14, 2020, 12:53:40 am »
OK I think I just figured it out. Apparently all of the rooms were disabled in the design rules.
I have no idea how this happened, I certainly didn't do it. Grrrrrr...
