Author Topic: Altium dragging component while holding Ctrl reversed?  (Read 2255 times)
Offline dmgTopic starter
« on: January 12, 2017, 04:33:34 pm »
I've been updated to Altium 17 an I've noticed that the behaviour when dragging an schematic component has been reversed, now it defaults to keeping wires connected and moves with disconnection if left Ctrl is pressed. Is it possible to switch it back?
Offline free_electron
    • SiliconValleyGarage
Re: Altium dragging component while holding Ctrl reversed?
« Reply #1 on: January 12, 2017, 05:02:46 pm »
 preferences ->Schematic ->graphical editing
in the options column. 'always drag'  (12 or 13 item in list ) : uncheck that.
17 also has altered the selection. when making a selection from top left to bottom right : select only items that are fully inside.
when making selection from bottom left to top right : select anything touching. the way Solidworks does it
Offline technotronix
    • PCB Assembly
« Reply #2 on: January 14, 2017, 09:50:42 am »
free_electron has given a nice solution. You should try it. It may work.
Offline richardlawson1489
    • PCB Assembly
« Reply #3 on: January 31, 2017, 11:47:44 am »
Yes, it is possible. Follow first_electron
