Author Topic: Antenna PCB Altium designer  (Read 7979 times)
Offline tarik85Topic starter
  • Country: dz
« on: August 28, 2016, 05:12:34 pm »
Hello guys,
i am new to altium designer and would like to design an antenna on pcb(altium designer) for my NFC (13.6Mhz),wpuld you please guide me by tutroial or something else?
thanks
Online T3sl4co1l
    • Seven Transistor Labs
Re: Antenna PCB Altium designer
« Reply #1 on: August 28, 2016, 06:59:19 pm »
Use a Net Bridge component.
Search for Altium documentation on how to do that.
As for the antenna geometry, the appnote for your controller IC will probably recommend something.
Seven Transistor Labs, LLC
Offline technotronix
    • PCB Assembly
Offline pix3l
  • Let's pix3l8e
« Reply #3 on: September 22, 2016, 01:05:07 pm »
There might be some useful info in this appnote from nxp: http://www.nxp.com/documents/application_note/AN11564.pdf
Also, it's 13.56MHz but you probably know that ;-)
Offline pix3l
  • Let's pix3l8e
« Reply #4 on: September 22, 2016, 01:09:19 pm »
Also depends if you want to make a PCD or PICC of course..
