Author Topic: Unable to move/dragging pcb component in Altium Designer  (Read 3689 times)
Offline Md Mubdiul HasanTopic starter
  • Country: kr
  • Lets learn more to be more inspired in Electronics
« on: October 05, 2021, 12:13:24 am »
I am using Altium Designer 21.6.4.
I have draw schematics, switched to pcb. Previously when I click on the schematic parts it also indicate/ highlights component in pcb. After I made some net classes I cant move parts in pcb.
What I did from Altium Designer help link as follows,
To have the connection lines move with the component when using Edit ► Move ► Component, as they do when just clicking and dragging the component in the PCB editor, "Comp Drag" must be set to "None". See Preferences ► PCB Editor ► General ► Other (section) ► Comp Drag set to "None". Either way, they will show on the component when things are done.
" alt="" class="bbc_img" />
Nothing happed with this setting.
Help me please,
Hasan
Hasan
Offline thm_w
  • Non-expert
Re: Unable to move/dragging pcb component in Altium Designer
« Reply #1 on: October 05, 2021, 08:27:33 pm »
Are you saying it used to work using the same version of Altium?
Can you select the component and see its properties?
If you can select it, can you press ctrl + arrow keys to move it around?
Maybe the part is locked or you have some filter active.
Online tszaboo
« Reply #2 on: October 05, 2021, 09:48:08 pm »
I've seen similar. Its a bug. Restart it, and it goes away.
The following users thanked this post: Md Mubdiul Hasan
  • Country: kr
« Reply #3 on: October 07, 2021, 11:48:59 pm »
In top of the middle pcb design window selection filter "component" was disabled.
Hasan
