Author Topic: Keeps adding a Plane layer  (Read 987 times)
Offline Spark-DoctorTopic starter
« on: July 24, 2022, 10:29:03 am »
I just started to layout a 2 layer board today and went to add a via. Added the first via, no problem. When i added the second via, Altium adds a dielectric and a plane layer to the stack up. I go in to stack up manager and i cant remove it.
Can anyone help????????
Online T3sl4co1l
    • Seven Transistor Labs
Re: Keeps adding a Plane layer
« Reply #1 on: July 24, 2022, 09:50:28 pm »
Go to place a via, press TAB.  Is it on a custom pad stack mode, perhaps?
Also the usual paranoia check: how long has it been since rebooting Altium?
Seven Transistor Labs, LLC
« Reply #2 on: July 27, 2022, 06:31:37 pm »
Found it in the end. It was a footprint i downloaded from Octopart. Deleted it and added the same part from Component Search Engine and all went away.
Thanks for your help though.
Ian
