Author Topic: schematic sheets B vs C size  (Read 1156 times)
Offline gogomanTopic starter
« on: February 18, 2020, 02:10:41 pm »
Hello, drawing a schematic in C and printing in B (11*17) results in the printed object not filling the entire sheet (It could be that the graphics are not scalable).
Is there a work around and is there a preferred PDF reader to use with Altium.
I tried custom scale in the printer output dialog box (yellow), the results were the same.
thanks
Online T3sl4co1l
    • Seven Transistor Labs
Re: schematic sheets B vs C size
« Reply #1 on: February 18, 2020, 05:16:56 pm »
B and C have complementary aspect ratios, so there has to be letterboxing or cropping.  Is that what you're referring to?
Seven Transistor Labs, LLC
Offline voltsandjolts
« Reply #2 on: February 19, 2020, 12:02:15 pm »
Thank goodness for the square root of 2 and ISO216.
The following users thanked this post: blueskull
