I have a project that has many plug-able sub-boards. I need to keep track of position/location/outline info between 10 or so projects.
Currently i have one special PCB doc that only has this sort of into in it, no actual PCB. It uses various layers for different location/outline info.
I then add this pcbdoc to all projects that need it.
If i need to update a size/position dimension i update the doc and then copy/paste all layers from it into each of my sub-board projects as needed
I was wondering if there's a better way to do this in a more automated way.
It would be awesome if there's a way to have layers that appears on all projects in a workspace, or on all pcbdocs within a project etc..
And if i update 1 doc all the other docs update automatically.
Is there any feature in Altium that would let me do this?
I'm using Altiums 15
