Author Topic: ERC to check voltages  (Read 1034 times)
Offline electricarTopic starter
« on: April 29, 2019, 01:16:56 pm »
Hey folks,
is it possible to check somehow if there are any capacitors or other components which have a less specified voltage (in their parameters) than the net they are connected to?
Some directives or net labels? I couldn't find anything...
Thank you in advance!
Cheers
electricar
Offline ajb
Re: ERC to check voltages
« Reply #1 on: April 29, 2019, 03:04:06 pm »
I don't think there's a built-in way to do this.  Sounds like a job for a user script.
You can almost use PCB filters to do a very crude approximation by using something like
InNet('+3V3') AND HasCompParameterValue('Voltage Rating', '16V')
but filters I think treat all parameter values as strings, so I don't think there's a way to make it understand something like 'ParameterValue >= 10V' or whatever.  Also there are some annoying limitations regarding selecting by pin (InNet) versus by component (HasComponentParameter) that make the logical query operators insensible.
