Author Topic: Altium Database  (Read 7120 times)
Offline Lippy01Topic starter
Altium Database
« on: February 03, 2013, 11:19:32 pm »
Hi All
I have created a database library for the company I am working at and have put the library on the private server. It works well except for when I want to edit/add a component while other people are using Altium. The excel spreadsheet I am using as my database says it is locked and is read only.
My Question is can I edit the excel spreadsheet (and Hence the Altium database) while other people are using Altium??
Thanks All
Lippy
Re: Altium Database
« Reply #1 on: February 07, 2013, 07:56:32 pm »
I think I've found the answer to my own question so I'll post it up.
After browsing the Altium forums (which I've just gained access to) I've found that it is normal for excel to lock up. The alternative is to use Access (which is better because it will eliminate sharing violations and Access will scale much better than Excel) or use a "proper" database like Microsoft SQL.
The forum post where I got this information from is found:
http://forum.live.altium.com/#posts/195638
Offline dda
Re: Altium Database
« Reply #2 on: February 07, 2013, 08:22:38 pm »
A google doc spreadsheet can be used and edited by many people at once.
Re: Altium Database
« Reply #3 on: February 07, 2013, 11:33:41 pm »
You can't use a google spreadsheet because you cannot give the file location to Altium
Online AlfBaz
Re: Altium Database
« Reply #4 on: February 08, 2013, 04:01:50 am »
When you used access did you have to enter the database connection string in somewhere. If I remember correctly there was a bunch of stuff you could specify in it such as passwords and sharing attributes etc...
Online AlfBaz
Re: Altium Database
« Reply #5 on: February 08, 2013, 04:23:44 am »
When you used access...
Sorry I meant excell
Offline Psi
Re: Altium Database
« Reply #6 on: February 08, 2013, 05:29:26 am »
My experience with Google docs is limited, but
You can mount your 'google drive' as a directory (or as its own drive letter using subst)
And you can open 'google docs' files from a 'google drive', so i don't see a problem.
« Last Edit: February 08, 2013, 05:32:07 am by Psi »
