If you get into a lot of polygons or complex designs, you may want to shelve some of the larger polygons while routing, that way they're not taking time to repour constantly. You can do that in the polygon manager, shortcut is T,G,M IIRC? Just remember to unshelve and repour before creating fabrication outputs!
