Hello,
I have issues using Altium's length tuning tools, they seem really incapable and not working well, both in Altium 17 and 19.
Lets start with the
Interactive Diff Pair Length Tuning tool. From my understanding, you have to look at signal length and not routed length as routed length can give false information due to overlapping traces. As you can see in attachment 1, I want to match the length to (at that time when I didn't complete length matching yet) the longest pair (CH3).
When I select the target length in attachment 2, you can see that it selects the
Averaged Length from pair CH3. (Keep in mind, I already matched the lengths of each trace in CH3).
When I start routing it, it is giving me the
Routed Length instead of the
Signal Length. This makes the
Net Length Gauge useless. I have to look in the PCB tab for the signal length that it gets.
Going to the
Interactive Pair Length Tuning you can see in attachment 3 that the
Net Length Gauge actually shows the signal length that it's tuning.
Also in attachment 4 you can see that the target length is the signal length.
Furthermore, Altium has the option to reshape the Accordion, but only for the
Interactive Pair Length Tuning tool. Why not for the
Interactive Diff Pair Length Tuning tool as well?
Length matching takes more time than needed because I have to go back and forth every time to really match signal and pair lengths as the tuning happens at multiple places throughout the signal/pair's path.
