Author Topic: Altium SmartPDF Doesn't Export PDF  (Read 3789 times)
Offline pi11235Topic starter
« on: May 09, 2012, 11:50:38 pm »
I have a schematic all layed out, and I run SmartPDF. It runs through all the steps, I hit finish, and it exits quickly with no errors, but no PDF file is at the chosen location. A outjob file is generated however. Is there something I'm missing?
« Last Edit: May 09, 2012, 11:59:57 pm by pi11235 »
Offline free_electron
    • SiliconValleyGarage
Re: Altium SmartPDF Doesn't Export PDF
« Reply #1 on: May 10, 2012, 01:22:31 am »
make sure that in the output job setting it says 'project' , not 'sheet '....
Offline Chris
    • PCB Component Libraries
« Reply #2 on: May 10, 2012, 07:09:16 am »
The only thing I can think of is that if your not doing it from the output job and running through the smart PDF wizard. If so then are the sheets selected when you get to that screen they should all be blue. Also if you have open PDF after export ticked does it apeare then?
Free to download Schematics Symbols and PCB Footprints.
www.pcbcomponentlibraries.com
