Author Topic: I can't get the board outline to gerber  (Read 12804 times)
Offline brianbangeTopic starter
« on: May 08, 2012, 10:31:42 pm »
I can't seem to find how to output the board outline in:
FILE - FABRICATION OUTPUTS - GERBER FILES - Drill drawing tab
Does anyone know how I can get the board outline in the gerber of the drill drawing.
I'm really wasting my day on this and have better things to do.
Thanks in advance,
Brian
Offline free_electron
    • SiliconValleyGarage
Re: I can't get the board outline to gerber
« Reply #1 on: May 09, 2012, 12:01:45 am »
draw the outline on a mechanical layer. in the project outputs create a 'final' project. there you can add the board outline to the plot.
Offline hesam.moshiri
    • MyVanitar
« Reply #2 on: May 09, 2012, 07:20:46 am »
Thanks in advance,
Brian
I had the same problem, here you can consider the reason and solution.
https://www.eevblog.com/forum/altium-designer/altium-gerber-export-board-outline/
Offline dfnr2
« Reply #3 on: May 09, 2012, 01:36:38 pm »
Free_Electron gave you the exact answer.  Not knowing your level of experience with Altium, I'll spell out the steps a bit more explicitly:
1. Use "Design->Board Shape->Create Primitives from Board Shape".  Create the primitives in a mechanical layer, and make sure nothing else is in that layer.
2. You should be using an OutJob to create the Gerbers.  Right click the "Gerbers" line, select config, go to the "layers" tab, and check the mechanical layer containing your outline.
3. Document your convention, including the name of the outline Gerber, in your README file.
Dave
« Last Edit: May 09, 2012, 01:39:14 pm by dfnr2 »
« Reply #4 on: May 09, 2012, 02:07:10 pm »
Here is another technique : i simply draw the outline on the keepout layer.
S-y. ( select all on layer )
Define board from selected objects.
Do design
In gerber. Export job , the keep out layer will automatically be injected as a separate plot.
If. You draw it on a mechanical layer , make sure the 'add to plot' is turned off, or it appears on every single gerber file.  Board houses don't like that as they have to remove it ...
« Reply #5 on: May 10, 2012, 12:25:00 am »
Thanks all. I finally figured this out after about four hours searching.
From now on I will put a copy of the board outline on the Drill Fabrication layer. That way I can get it on my gerber of the fab, but not on the other layers.
Brian
