Author Topic: Default values for a custom schematic library  (Read 2428 times)
Offline redrobingardenTopic starter
« on: May 23, 2012, 08:26:02 pm »
Hi guys! This is my first post in this wonderful blog that I should have joined years ago.
Here's my question. I use a custom schematic library for a project I'm making. Every time I add a new component, it is automatically filled with a bunch of default values that happen to be a PIC MCU I used once. So, every time i add a new blank component, and I have to go in there and delete all the default microchip pic values. I've been doing this way too often, and I'm sure there's a way to get at the default values somewhere.
Anyone have any idea how I can fix this?
Thanks a bunch for reading!
Offline Psi
Re: Default values for a custom schematic library
« Reply #1 on: May 23, 2012, 11:05:08 pm »
How exactly do you mean full of default values.
Do you mean that every time you click the 'add' button in the schematic editor you get a physical PIC mcu symbol and you must delete it plus all its pins and labels so you can start your new schematic symbol ?
Or is it more about default properties like value / package version / publisher. etc. all the stuff you get when double clicking on a component.?
Normally when i want to make a new schematic symbol in my library i go find something similar to what i want in one of my projects. Then i right-click/copy that and right-click/paste into the schematic editor library window.  That way i'm not starting from scratch all the time.
« Last Edit: May 23, 2012, 11:08:39 pm by Psi »
« Reply #2 on: May 24, 2012, 12:28:22 am »
Thanks for the reply!
When I click on add in my schematic library i get a component has footprints of a specific PIC along with default property values for that specific PIC.
Your advice sounds great (i'm an altium n00b) I never did that but will certainly be doing that in the future.
I do like importing parts from suppliers and starting off with that data though. When I do that, I get the supplier properties along with the damn PIC values.
