Author Topic: Bad connection between track and pad  (Read 3274 times)
Offline rozehTopic starter
« on: November 10, 2015, 01:30:57 pm »
Hi guys
I have problem to draw some tracks. look at this image:
For example in this image, one of the pads is connected very well but there are three pads with poor connections as you can see. What's the problem? how to figure out this problem?
Mark Twain — 'The two most important days in your life are the day you are born and the day you find out why.'
Offline free_electron
    • SiliconValleyGarage
Re: Bad connection between track and pad
« Reply #1 on: November 10, 2015, 01:39:14 pm »
You have clearance rule violations. Solve those and the problem will go away. Altium stops at that edge because the design rule checker says : can't go there, it's too narrow.
« Reply #2 on: November 10, 2015, 01:53:25 pm »
How to solve it?
Why the pads of the MCU are loaded with plus sign?
« Reply #3 on: November 10, 2015, 02:04:26 pm »
This is the result of design check rules:
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: November 10, 2015, 02:25:56 pm »
http://techdocs.altium.com/display/ADOH/Design+Rules
Attached: open the ZIP, place the .rul file in your project folder, and follow the instructions above to import design rules.  The built-in defaults are a bit too basic.  This should be a better start.
« Last Edit: November 10, 2015, 02:31:10 pm by T3sl4co1l »
Seven Transistor Labs, LLC
« Reply #5 on: November 10, 2015, 04:34:58 pm »
Thanks
Before applying the rules:
After:
And its rule check:
« Reply #6 on: November 10, 2015, 04:54:02 pm »
How to solve it?
Because those are violations against The design rules. you are most likely violating clearance rules
« Reply #7 on: November 10, 2015, 04:56:28 pm »
type <D><R> ( Design - Rules )
A window will open.
Look in the list for clearance rules and set those correctly per layer
Look in the list for width rules and set those properly
Online T3sl4co1l
« Reply #8 on: November 10, 2015, 06:19:36 pm »
You didn't import the rules correctly.  I have 24 items on the report, from the project I exported the rules from ( http://seventransistorlabs.com/Images/AltiumRuleCheckReport.png ).
Also, check that the rules are ticked for batch processing (T, D): http://seventransistorlabs.com/Images/AltiumRuleCheck.jpg
Offline ConKbot
« Reply #9 on: November 13, 2015, 02:36:23 am »
For a design rule to help you find those, rather then having to just look closely,
http://www.newelectronics.co.uk/electronics-videos/altium-design-secret-23-advanced-setting-of-the-width-rule/62909/   :-+
AV sync is a bit weird in the video, but you dont see a person talking, so its not that bad.
