Author Topic: Trying to make an Arduino shield, but I have a colision problem  (Read 2707 times)
Offline sensoTopic starter
  • Country: pt
    • My AVR tutorials
« on: November 22, 2012, 01:06:43 pm »
Good evening, sorry for the not so clear subject, but its not easy to explain with a handful of words.
So, I'm trying to make an Arduino shield, and so I have created a footprint that has the headers that will match up with the Arduino headers, but when laying out the pcb, Altium says that I have a colision with the componentes between the headers, because it assumes that the headers are a monolithic part.
Is there a way to circunvent this, or will I have to use loose header and align then in the pcb.
Image that will help understand my problem:
  • Country: pt
    • My AVR tutorials
Re: Trying to make an Arduino shield, but I have a colision problem
« Reply #1 on: November 23, 2012, 06:07:37 pm »
Any ideas? (sorry for nagging  :-[ )
Offline gxti
« Reply #2 on: November 23, 2012, 06:23:29 pm »
Same answer as for the other guy with clearance issues -- draw a 3D body and it will be used for clearance calculation instead of the bounding box.
  • Country: pt
    • My AVR tutorials
« Reply #3 on: November 23, 2012, 09:43:07 pm »
I will try to add 3d models of stackable pin headers and I will see if it solves the problem.
Thanks  ;)
