Author Topic: Altium Designer 22 does not even feature "via in pad". Are you kidding me?  (Read 1748 times)
Offline dastructhmTopic starter
kindda backwater, hey?
 :o
fortunately, my fabricator just told me that "don't worry, we'll manufacture your design as if they were vias in pad.", even though I simply placed vias over pads... :popcorn:
« Last Edit: October 10, 2022, 08:10:49 am by dastructhm »
dastructhm = data structures and algorithms
Offline Jester
Well you could certainly do it with older versions, I was using it on dense BGA footprints about 10 years back with version 13
The following users thanked this post: dastructhm
Offline voltsandjolts
It seems to be fashionable these days to start nonsense threads without first taking a moment to check the facts, educate yourself and save any embarrassment. Oh well. Is that you, treez?
The following users thanked this post: thm_w, Pseudobyte
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
How are you expecting it to behave? If you want a via in the pad, you put a via in the pad...
“They Don’t Think It Be Like It Is, But It Do”
Offline KaneTW
What are you talking about? I manufactured several VIPPO boards using Altium. Just put a via in the pad and set it to type 7 filled/capped, done.
ooops, sorry, I didn't know. embarrassed indeed.  :palm:
Offline Kasper
I've done vippo and blind vias in outdated circuit studio and had no problems with fabricator.
