Started to split up the design, use sheets, repeats, and lets see how many thousand errors I will get when I try to go to the pcb layout.
The first thing that is confusing me is passing nets/signals between sheets, but if needed I will nag you guys again.
Thanks for the fast response.
Up to A3 it doesn't complain or lag a bit, in A2 sheet its bad, and gets worse as the design goes, but with hierarchical sheets its all more organized and I learned something new today.
I have been using Altium with the measly HD3000 and even with the 3D never had a issue, just tried with the dedicated today due to this behaviour, I believe that a good card will influence in real men designs, not my puny little inventions, and yeah the gt630m is very old, its root is the gt425M that is over 6 years old.
I'm also on a Full HD display, but its only 15.6".
In the offtopic response, I bought a 24" FHD Asus dispay for like 120€, then I bought the FHD display for the laptop and never used it again
