Author Topic: Unable to connect a single trace to several op amps.  (Read 1793 times)
Offline PlasmateurTopic starter
« on: March 06, 2017, 12:54:16 am »
I am attempting to connect two single traces to three different op amps for the purposes of powering them from a single source.
Is this a limitation of CircuitMaker or do I need some kind of passive power distribution component?
Offline Dubbie
Re: Unable to connect a single trace to several op amps.
« Reply #1 on: March 06, 2017, 01:07:29 am »
Do you have the connections in your schematic?
« Reply #2 on: March 06, 2017, 05:33:12 am »
I was able to fix the problem. Thank you!
« Reply #3 on: April 09, 2017, 11:59:12 pm »
Sorry for not updating with what the solution was.
I was fairly new to this program. The problem was somehow I was not connected to a net at the start of my trace. By not initially being connected to a net, attempting to "branch off" a trace would not work as soon as I connected the second branch point.
