Author Topic: How to unroute and reset component placement  (Read 2315 times)
Offline nick39Topic starter
  • Country: ar
« on: March 06, 2021, 01:49:00 pm »
I have a project that has all the components placed and routed. I would like to know how can I unroute everything and reset all the components locations so that I can place and route everything again.
Thanks!
Offline PlainName
  • Country: va
Re: How to unroute and reset component placement
« Reply #1 on: March 06, 2021, 04:30:52 pm »
On the route menu, select 'un-route' (at the bottom) then 'all'.
For the components... I'd just select them all and drag off-board :)
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
« Reply #2 on: May 07, 2021, 02:26:45 pm »
If you select all your components you can reset the placement with. T >> O >> O
“They Don’t Think It Be Like It Is, But It Do”
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: May 07, 2021, 07:22:58 pm »
Mind that polygons, regions, etc. may or may not be "unrouted" in the process, and you'll have to delete them separately.  (I almost never use the feature, I think most types are removed but polys stick around?)  Also mind locked objects if any.
I find it handy to keep some of the initial placement; the arrange-components commands tend to randomize things.  I guess if you're going for a complete cold start that's useful, but even a bad (but complete) placement is still a good starting point.  But YMMV.
Seven Transistor Labs, LLC
Offline alexwhittemore
« Reply #4 on: May 07, 2021, 08:50:04 pm »
Can confirm - "unroute" doesn't kill polygons, you have to delete them. Also, I like the shortcuts U-U-N (roUte, Unroute, Net) and U-U-A (roUte, Unroute, All) although I only really use the first.
Agree with Tim that having SOME placement is a better starting point than not, but I'll add:
If you're going to the extreme of completely ripping out all routing and placement, might as well just start with a brand new .PcbDoc. Maybe you need to keep design rules or something? I think you can get away with highlight all>delete then Design>Import fresh.
