This is an Issue which very rarely happens to me but when it does it drives me up the Wall.
I believe this only happens on Mechanical Layers as it most usually occurs when I am cleaning up cosmetically old Board Designs (Overlay and such).
So you would think you can just do your regular, cut, paste, move actions during repetitive tasks in the design process.... however sometimes I can only cut (then after that not paste ofc) not copy nor move some lines or tracks.
I check they are unlocked... I even move them to different layers, I check my sanity... nothing.
Also nothing in the clipboard... it makes the effort but in reality its blank even after cutting (and dissappearing).
In the end I start redrawing over it and copying that.
Anyone else has this happen or is it just me?
