Author Topic: Altium Designer - Set PCB Thickness ?  (Read 18977 times)
Offline David_AVDTopic starter
« on: July 28, 2015, 04:31:39 am »
I have a PCB that I've exported as a step file, but the board thickness seems to be set as a default 0.3mm or so.
Is there a way to set the PCB thickness (in general or for the step export) ?
Online enz
Re: Altium Designer - Set PCB Thickness ?
« Reply #1 on: July 28, 2015, 07:08:33 am »
This is done in the Layer Stack Manager. Menu: [Design] -> [Layer Stack Manager]
Altium calculates the total thickness of the board from the thickness of each layer that you specify there.
« Reply #2 on: July 28, 2015, 10:44:41 pm »
Excellent - thanks very much for that.  Job done!   :-+
Offline DutchGert
« Reply #3 on: August 01, 2015, 11:37:50 pm »
How can u produce a board without defining the layer stack in the first place?
Offline Zman
« Reply #4 on: August 02, 2015, 07:29:49 am »
nothing is wrong with using default layer stack which is standard top/bottom two-layer (unless you have special requirements)
Information wants to be FREE!
