Author Topic: Select Revision State is not yet Released  (Read 959 times)
Offline miller196Topic starter
« on: October 13, 2023, 06:24:38 pm »
Class   Document   Source   Message   Time   Date   No.
[Fatal Error]   539 (CMP-001-00087-1)   Component Validator   Cannot link to model: PCC-004-000001-1. The select revision is not yet released.   2:19:16 PM   10/13/2023   1
[Error]   PCB - CAPACITOR - MLCC - CAP 0_2 RADIAL DISC (PCC-004-000001-1)   Component Validator   PCB - CAPACITOR - MLCC - CAP 0_2 RADIAL DISC (PCC-004-000001-1) revision is in inapplicable state   2:19:16 PM   10/13/2023   3
I know this is a simple fix, but I've recently gained control over a library with the task of updating the component parameters. In doing so I've been coming across the error, "Select Revision State is not yet Released". I feel like Altium can be such a never ending black hole when trying to find any form of specific information |O. So upon stumbling into this forum I hope someone whose much more informed than I am can lend me some assistance. I greatly appreciate any assistance!
Just a couple more details this error originated from when I attempted to simply apply an updated parameter to a component. This happens when I do both a batch edit and a single component edit as well.
« Last Edit: October 13, 2023, 06:34:04 pm by miller196 »
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Select Revision State is not yet Released
« Reply #1 on: October 16, 2023, 12:00:14 am »
Sounds like you are working with a managed/workspace component library? If so, have you checked that revision 1 of PCC-004-000001 actually exits?
« Reply #2 on: October 17, 2023, 04:28:07 pm »
Huh, it seems that it didn't exist. Thanks for your help.
