Author Topic: Net colors not overriding  (Read 6174 times)
Offline PlainNameTopic starter
  • Country: va
« on: August 02, 2021, 12:03:51 am »
Is this just my problem or has it popped up for everyone?
I set a net color and that works fine. Do a few more (typically power nets), seems to be fine. Hit F5, nothing. Try via the view menu - enabling and disabling net color override has no effect. Open a different schematic page and that shows, or doesn't show, the net colors according to the setting, but once it's open no amount of toggling the setting changes things. To see any change, I have to close the document and then open it again.
I am pretty sure it used to work dynamically as intended, but closing and restarting Altium doesn't fix it.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Net colors not overriding
« Reply #1 on: August 02, 2021, 05:57:32 am »
Altium 21? If so there seems to be a bug with setting/displaying net colours
  • Country: va
« Reply #2 on: August 02, 2021, 10:39:31 am »
Thanks. Yes, it's the latest 21. Didn't see anything on bugcrunch, but maybe if it's a new problem everyone is waiting for someone else to kick up a fuss :)
Offline asmi
« Reply #3 on: August 03, 2021, 08:13:59 pm »
Working just fine over here. Altium 21.6.1.
  • Country: va
« Reply #4 on: August 03, 2021, 09:26:56 pm »
Ah, I think I haven't spelt out the problem clearly. Some screenies:
First, Override enabled. You can see the coloured wires and the tickbox for enabling is ticked.
1241889-0
Press F5 and the tickbox is now unticked, but the wires remain coloured.
1241891-1
Close and reopen the document and the wires are now uncoloured, as they should be. The problem is that changing the setting does nothing, but closing a reopening the document shows the change. Thus it seems that the setting is only applied when the document is opened.
  • Country: va
« Reply #5 on: August 09, 2021, 01:05:06 pm »
Word from Altium is that it's a bug and will be fixed soon.
Offline tooki
« Reply #6 on: October 12, 2021, 12:59:38 pm »
I wonder if this is related to a color issue I’ve had, namely, of the rat line color selection not applying. In many view configurations, the rat lines are nearly impossible to see while placing a component.
  • Country: va
« Reply #7 on: October 12, 2021, 01:11:39 pm »
I have no actual idea, but I suspect not. The issue here is that the colours couldn't be switched on but once it was managed they were fine (the non-fix fix is apparently to select a component, which will cause an update to occur). Your problem sounds like it's a permanent visibility thing.
