Author Topic: Altium 6 month free viewer licence expired  (Read 5591 times)
Offline ocsetTopic starter
« on: July 06, 2019, 03:32:49 pm »
Do you know if its possible to renew this free Altium viewer?
Ours has just expired.
The following users thanked this post: eliocor, zapzapouch
Offline thm_w
  • Non-expert
Re: Altium 6 month free viewer licence expired
« Reply #1 on: July 09, 2019, 07:51:05 pm »
Ask altium support.
The free Summer 09 viewer that was available on their site appears to last forever.
The following users thanked this post: ocset
Offline julianhigginson
« Reply #2 on: July 10, 2019, 05:41:21 am »
You need to ask Altium support for the "free 6 month free 6 month viewer license extender license"
Be warned though - next year you will need to ask them for the "free 6 month free 6 month free 6 month viewer license extender license extender license.
And it only gets worse from there.  I think that their business model is eventually you will get so confused, that you just end up paying the $10k for the full version to never have to ask for another level of extension again.
The following users thanked this post: ANTALIFE, Ysjoelfir, ocset, zapzapouch
Offline ddavidebor
    • Smartbox AT
« Reply #3 on: July 15, 2019, 08:54:41 pm »
Hello,
You can pretty much download unlimited free licenses from the link the give you in the email.
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline zapzapouch
« Reply #4 on: January 05, 2022, 05:19:40 pm »
Hello,
When I click the link in the old "Your Viewer License Registration Details" email, it downloads a new .alf file, but if I import this as a standalone license, it says it "Expired" 6 months ago.  Is there a trick to getting a new license that's not already expired?
That's my impression, too.  Every time I need to view a .pcbdoc file, Altium says the viewer license has expired.  I try to renew it at https://www.altium.com/altium-designer-viewer, and it says "REGISTER FOR YOUR FREE 6-MONTH VIEWER LICENSE" but despite the page "loading" for several minutes, the registration form is a blank white space.  If I reload the page, sometimes it appears. I try to fill it out, press Submit, and nothing happens.  Eventually maybe it goes through.
Or maybe I try to register an AltiumLive account and it says things like "An AltiumLive already exists for this email address but needs to be activated by clicking the link in the activation email."  "Failed to send activation email"  If I click an old activation email, it says "Insufficient privileges to enter this space".  etc. etc. etc.
After a lot of clicking and trying things, it inexplicably starts loading .pcbdoc files again.  Then next time I go to use it, it has expired again.
This doesn't make me want to pay $10k for the software though, it makes me want to demand that our factories never use their software or send us .pcbdoc files.
How do you use this?  I installed from https://techdocs.altium.com/display/ALEG/Altium+Designer+Summer+09+-+Software+Updates but it says "You are not using a valid license. Click Sign in to retrieve the list of available licenses."
It seems to just have the same licensing problems as the current version.
Offline thm_w
  • Non-expert
« Reply #5 on: January 05, 2022, 10:13:44 pm »
Thats the full install. They used to have the viewer only download on their site, no license needed, seem to have removed it. I'll look around.
There is also this: https://www.altium.com/viewer/
edit: found a download here, virus scan seems ok https://altium-designer-viewer-edition.software.informer.com/download/
« Last Edit: January 05, 2022, 10:28:25 pm by thm_w »
The following users thanked this post: zapzapouch
Offline zapzapouch
Offline pointhi
  • Country: at
« Reply #7 on: January 06, 2022, 03:50:09 pm »
If you need a quick offline viewer, try to use KiCad 6 to import the PcbDoc file. Depends on you actual use-case if that makes sense for you.
The following users thanked this post: Weston, zapzapouch
Offline zapzapouch
« Reply #8 on: January 08, 2022, 12:31:03 am »
I tried Kicad but it doesn't work on my files.
https://www.kicad.org/blog/2020/04/Development-Highlight-Altium-Pcb-Importer/
 I'll try the summer viewer next time my license expires
Offline zapzapouch
« Reply #9 on: January 10, 2022, 03:27:55 pm »
The Summer 09 viewer works with no license hassles!
The only issue is I can't press "OK" in configuration dialogs, like changing the layer colors or assigning "Ctrl+F" to "Flip board".
The OK buttons are just grayed out.  Maybe I can hack the registry to change these or something.
Offline thm_w
  • Non-expert
« Reply #10 on: January 10, 2022, 09:57:48 pm »
I didn't even realize you could edit that shortcut.
Colors might be in here: C:\Users\*username*\AppData\Roaming\AltiumDesignerSummer09_Viewer\ViewConfigurations
Shortcuts are in here: C:\Program Files (x86)\Altium Designer S09 Viewer\System\AdvPcb.rcs
PL PLPCB:FlipBoard                              Command='PCB:FlipBoard'                                           Caption='Flip &Board '                           Image='FlipBoard.bmp'        Shortcut1='Ctrl+F'                            Shortcut2=''                           Params='Action = FlipBoard'        Description='Flip Board'
Offline zapzapouch
« Reply #11 on: January 10, 2022, 10:15:16 pm »
That works!  :-+
