I'm slightly embarrassed to even ask this as I'm sure there is a simple solution.
There are often a number of items in the SCH (such as Z1, Z2, Z3, screws, nuts, washers and other HW items) that are added to the SCH because they will then show up in the BOM.
There are some items in the PCB only with designators such as mounting holes (X1, X2, X3 etc).
When going from SCH to PCB, the ECO wants to add the Z1, Z2 etc hardware to the PCB and remove the X1 X2 etc mounting holes.
Is there a way to prevent this by changing a parameter for Z? X? components or by locking them?
