Author Topic: Altium: How do i remove this gap between the stackup layers in 3D mode  (Read 2484 times)
Offline PsiTopic starter
I'm using Altium 20.1.14
Anyone know how to get rid of these gaps between the stackup layers in 3D mode.
My Flex pcb is 0.1mm thick and the stackup confirms this, but in 3D it's more like 2mm due to all these gaps.
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Altium: How do i remove this gap between the stackup layers in 3D mode
« Reply #1 on: October 19, 2020, 05:34:45 pm »
can i get a screenshot of the layer stackup window
“They Don’t Think It Be Like It Is, But It Do”
« Reply #2 on: October 22, 2020, 07:20:25 am »
Thanks,
Yep, will post pic in a few days.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: October 25, 2020, 03:39:00 pm »
there is a slider in 'view configuration , second tab' where you can 'explode' the board. check that it is set to 0
« Reply #4 on: October 26, 2020, 11:53:46 am »
That was one of the things I checked. but it was already zero
« Reply #5 on: October 26, 2020, 08:20:53 pm »
Some more pics.
That grey block in first pic is a 0.1mm height extruded 3D body with 0mm standoff for reference.
So looks like issue is with the top coverlay layer. Other layers look ok. Including bottom coverlay.
Offline Pseudobyte
« Reply #6 on: October 28, 2020, 01:30:38 pm »
I can't seem to recreate the issue you are seeing. I tried your stack-up as well as adding different board regions trying to break it. I am running 20.2.5
Sorry i couldn't help
« Reply #7 on: October 30, 2020, 01:03:41 am »
Thanks anyway,
I might try to make a brand new project, see if that has the issue.
I can always move everything to the new project.
Offline Helloworld33
Did you ever figure this out?
Nope
