Author Topic: Altium Designer 19 Schematic Device Missing Pins / Not Showing  (Read 2018 times)
Offline offlineTopic starter
« on: October 02, 2019, 01:10:11 am »
I have two devices in a schematic, not all the pins are showing in the sheet, under properties they are all checked show all.
The missing pins/names seem to have a lighter grey. Any ideas?
144 pin ARM Microcontroller
56  pin NOR Flash
Offline SerieZ
  • Zap!
Re: Altium Designer 19 Schematic Device Missing Pins / Not Showing
« Reply #1 on: October 02, 2019, 07:18:25 am »
The Component is split into several Parts. You are currently only seeing Part A.
You may want to go under Properties and select Part A, B, C.... and place them separately or create a whole new Symbol for the Component if you want all the Pins on one single Symbol.
With a Component with so many Pins I am not sure If that makes a whole lot of sense.  :)
As easy as paint by number.
« Reply #2 on: October 02, 2019, 01:24:33 pm »
Found it, thanks  :)
