Author Topic: AD14, selecting top overlay in specific area  (Read 3225 times)
Offline WarhawkTopic starter
    • Personal resume
« on: November 25, 2015, 09:51:14 am »
Hi all,
I am just about to finish my first layout in AD14 and doing "a final touch". I am trying to select (and then delete) top overlay component primitives (silkscreen) in some specific area. When I do "find similar" it selects all similar primitives including my company logo etc. Which I don't want to.
On the other hand when I display only a top overlay and use even "select all from layer", it selects whole components but no primitives. For that reason my filter "(Layer = 'TopOverlay')" and Apply to Selected does not work.
Could somebody give me a hint how to select a Top/Bottom overlay in a specific area?
Thanks in advance !
PS: Yes, I googled and experimented but without any luck.
PPS: Yes, it may be faster to do it manually than asking on the forum but I am learning a new tool and may use these principles in future.
    • Personal resume
Re: AD14, selecting top overlay in specific area
« Reply #1 on: November 25, 2015, 10:14:18 am »
All right, I found a method using
"InRegionRelative(0,0,3000,1200) and (Layer = 'TopOverlay')"
Is there a simpler / different way ?
Offline ludzinc
    • My Misadventures In Engineering
« Reply #2 on: November 25, 2015, 10:19:47 am »
Select, inside area.  Done.
    • Personal resume
« Reply #3 on: November 25, 2015, 10:58:18 am »
I would not ask if this worked for me  ;)
Offline ajb
« Reply #4 on: November 30, 2015, 06:51:25 pm »
So you're trying to select primitives that are parts of components?  In PCB Inspector, is "Lock Primitives" selected for the components in question?
AD is a little funny about primitives, as you've seen sometimes they get filtered and sometimes they don't.  There are also some options in PCB filter for free/'in component' primitives that you could play with.
    • Personal resume
« Reply #5 on: December 02, 2015, 07:59:29 pm »
- Yes exactly. And yes, primitives are unlocked. I can select them manually or even do multiple selections holding shift (and click)
I will check it out tomorrow. Thanks for the tip.
