Author Topic: Altium - Copy Room Format  (Read 8622 times)
Offline David_AVDTopic starter
« on: March 19, 2013, 11:29:16 am »
I am designing a new 2 channel board that is basically a cut down version of a 5 channel design I did previously.
The new board uses the same channel sheet symbols as the old project.  I have placed and sized the rooms on the new board.
What I'd like to do is copy the room format from one channel in the previous project PCB to the rooms of the new project PCB.
How do you do this?  The Copy Room Format function only works within the same PCB file as far as I can see.
Offline caffeinatedbard
Re: Altium - Copy Room Format
« Reply #1 on: March 19, 2013, 12:37:52 pm »
I haven't used this myself but thought it might be helpful.
http://wiki.altium.com/display/ADOH/Snippets
-bard
« Reply #2 on: March 19, 2013, 09:22:18 pm »
Thanks, I'll check that out.  It might be a viable alternative.
« Reply #3 on: March 25, 2013, 09:59:13 pm »
Snippets don't seem to what I want for this multi-channel design.
Does anyone else work with rooms a lot?
Offline Mikekoz13
« Reply #4 on: March 26, 2013, 05:20:15 pm »
Why not just start with a copy of the old design and "throw away" the portions you don't need?
If that won't work for some reason, SNIPPETS should work for what you want. After adding the new "snippets" to your current board you will probably have to resynchronize your schematic and PcbDoc.
