Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
How to narrow down search in SVNDBLIB?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How to narrow down search in SVNDBLIB? (Read 552 times)
mengfei
Regular Contributor
Country:
on:
August 04, 2023, 02:56:38 am »
is there a way to narrow down the search in SVNDBLIB? I can only search for one line & no separator can work.
say searching for a 75ohm 0402 5% Yageo type, i can only place 75ohm in the search bar, is there a way to filter a search? thanks
Logged
ajb
Super Contributor
Country:
Re: How to narrow down search in SVNDBLIB?
Reply #1 on:
August 04, 2023, 03:10:31 am »
Not as far as I know, but you can select columns for hierarchical grouping which may help:
https://youtu.be/7id84tbtCPQ
I’ve set up my dblib to take advantage of this, with a set of hierarchical category columns used for grouping. So for example I can select resistors > 0402 and then search for ‘75R’ (or more likely, just sort by value and scroll through the list). Works well enough.
Logged
mengfei
Regular Contributor
Country:
Reply #2 on:
August 04, 2023, 05:43:21 am »
OK, thanks.
I'll look into that
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
