Author Topic: Parameter sweep in Mixed Sim  (Read 2447 times)
Offline BudTopic starter
« on: April 17, 2017, 02:38:04 am »
I am trying to sweep a voltage source's AC phase but the parameter does not show up in Mixed Sim Parameter Sweep Setup dialog, only DC parameter seems to be available for VSIN voltage sources. How do I set up the simulation to sweep V5 phase ?
Online T3sl4co1l
    • Seven Transistor Labs
Re: Parameter sweep in Mixed Sim
« Reply #1 on: April 17, 2017, 03:14:15 am »
Use a SPICE .param statement:
https://www.seventransistorlabs.com/Images/AltiumSweepPhase1.png
https://www.seventransistorlabs.com/Images/AltiumSweepPhase2.png
(Set the parameter in the simulation configuration dialog.)
Seven Transistor Labs, LLC
« Reply #2 on: April 17, 2017, 05:01:51 am »
Sorry cant figure out from your reply/screenshots how to do it. Is an Altium tutorial on that ?
Online T3sl4co1l
« Reply #3 on: April 17, 2017, 06:14:45 am »
These are the dialog steps.
https://www.seventransistorlabs.com/Images/AltiumSweepPhase3.png
https://www.seventransistorlabs.com/Images/AltiumSweepPhase4.png
It's just SPICE: whatever expression is in the curly braces, is evaluated at compile time.  You can use expressions and parameters instead of constants, and then you can sweep the parameter.
« Reply #4 on: April 18, 2017, 02:22:41 am »
I see. So you create a Global parameter, select it in the Parameters Sweep and also assign it (in curly brackets) to the component you want to sweep (in my case a voltage source).
Did that and it worked, thanks for the tip!
