Author Topic: ActiveBOM  (Read 1554 times)
Offline daedalusTopic starter
ActiveBOM
« on: May 18, 2019, 09:16:05 am »
When using ActiveBOM, is there an easy way to build a basket at a supplier's website from a given activeBOM design? Say i have selected parts from Digikey for a 5 off run of my design, is there a way to automatically build a digikey basket with all the parts i need, labelled with the designators from the project?
I have recently done this by hand for a project and was thinking that surely there is an automated way to do this?
Offline ajb
Re: ActiveBOM
« Reply #1 on: May 20, 2019, 04:06:23 pm »
You should be able to do this with an outjob.  Should just be a matter of making the ActiveBOM the source of a BOM output, and then setting up the appropriate BOM template and filtering.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: ActiveBOM
« Reply #2 on: May 20, 2019, 07:35:13 pm »
I forget how good the integration is (I've never used it), but if nothing else you can generate a BOM with the relevant fields (Mfg/Supplier PN, qty) and import that into Digi-Key, or Mouser or any other supplier that has spreadsheet import (which is many!).
Seven Transistor Labs, LLC
Re: ActiveBOM
« Reply #3 on: May 21, 2019, 08:27:32 am »
Thanks for that, I will give the spreadsheet route a try.
