Author Topic: Anyone tried Altium with the Intel Arc A770 GPU?  (Read 1355 times)
Offline Numex106Topic starter
« on: January 29, 2023, 09:19:32 pm »
Has anyone tried the latest Intel Arc GPUs (A770 or A750) with Altium Designer?
https://www.altium.com/documentation/altium-designer/system-requirements
Altium's recommended system requirements only recommends DX10 support or better.
I do have some fairly large projects (think 10" x 10" PCB with couple thousand components) and want it to smoothly. But I was more wondering if there were any bugs or quirks when running the arc gpus with Altium.
Thanks!
Offline thm_w
  • Non-expert
Re: Anyone tried Altium with the Intel Arc A770 GPU?
« Reply #1 on: January 30, 2023, 09:27:29 pm »
If you want it to run smoothly, whats the issue with just getting an older nvidia GPU? Its not like you need the latest most powerful GPU.
I'm sure a 1070, 2060+ or similar would be fine.
The only justification is if you want to have the machine as dual use for gaming and CAD.
The following users thanked this post: Numex106
Offline SiliconWizard
« Reply #2 on: January 31, 2023, 08:50:27 pm »
Even a 1060 works fine and is already overkill for Altium.
Even a much less powerful GPU would work.
As to the new Intel Arc GPUs, while interesting, at this point feedback shows that drivers are still very buggy with a lot of limitations, so I'd suggest staying away, at least until this all gets more stable.
The following users thanked this post: wraper, ANTALIFE, Numex106
