Author Topic: Altium Designer 18.1.7  (Read 3250 times)
Offline ryanengineeringTopic starter
« on: April 01, 2019, 05:45:30 am »
Hello All, I am performing the finishing touches on a board and trying to add a logo, I did all of the steps that I have found on the net ( Convert to black and white, save as BMP ) copy and paste wont work, I also did the alternative method of placing object from file with no luck.... Any ideas out there? can someone that has luck with this convert for me? Thank you -Ryan
Offline maxpayne
Re: Altium Designer 18.1.7
« Reply #1 on: April 05, 2019, 03:07:20 am »
You need to run attached delphi script to include a logo on the PCB.
Offline Psi
« Reply #2 on: April 05, 2019, 03:16:59 am »
The copy/paste thing needs to be done correctly.
Ya need to copy the image not the file and some programs don't conform to the correct copy/paste spec.
Also the only color that will import is 100% black, (0 red 0 blue 0 green).
MSPaint in Win10 works fine.
Load any image into mspaint that has some 100% black in it, draw selection box around the area you want and click the 'copy' button.
Then paste into an Altium PCB document
« Last Edit: April 05, 2019, 03:19:37 am by Psi »
The following users thanked this post: ajb
Offline radar_macgyver
« Reply #3 on: April 05, 2019, 05:12:27 am »
You can import a DXF. My preferred method is to make a custom Truetype font and then just create a string object and use that font. Creating the font can be painful though.
Offline ajb
« Reply #4 on: April 05, 2019, 06:50:12 pm »
That's kinda neat, I didn't realize that worked.  I guess I never tried copying the image the right way.  Doesn't seem there's any way to control the size though?
Offline Psi
« Reply #5 on: April 05, 2019, 10:44:57 pm »
Yes, there is a way to do that. (at least it works in AD15 that i'm using)
When you first paste the image into Altium it will have "handles" You can drag those to make it bigger/smaller.
(If you click off the object you will lose the handles. Getting them back is annoying you have to click "Resize Union" and then click in the right place)
« Last Edit: April 05, 2019, 10:50:23 pm by Psi »
Offline ubbut
« Reply #6 on: April 07, 2019, 08:18:25 pm »
