Author Topic: [Solved] Cannot route on middle layers  (Read 1424 times)
Offline blueskullTopic starter
  • Country: cn
  • BA7LKP
« on: October 14, 2019, 01:34:43 am »
I created a 4L design, which I started from top and bottom.
Today I was working on its middle layers, and Altium threw errors on clearance violation, which I didn't.
File is attached, if anyone can take a look at it.
The trace under investigation is 1V0 on the left bottom corner of the large chip on the right side of the board.
Version: 19.1.8 through auto update. Thanks.
//Solved.
« Last Edit: October 14, 2019, 02:55:29 am by blueskull »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: [Solved] Cannot route on middle layers
« Reply #1 on: October 14, 2019, 03:22:51 am »
"Everything" including design rules?  Classes?
That's one thing that can be propagated poorly from SCH, classes.  Obviously the PCB-exclusive classes, but I've seen net classes not sync correctly.
Could also just be general paranoia, restart Altium etc.  Who knows. :-//
Seven Transistor Labs, LLC
