Author Topic: Non Plated Through Hole Settings  (Read 2990 times)
Offline tarun172Topic starter
« on: March 13, 2023, 07:57:34 pm »
Hi all,
        I am running into issues setting non-plated through hole in Altium. I have configured hole as mounting hole 3.08 mm non-plated, 0.127 mm solder mask expansion. When I unselect pad option as plated and run through DRC and DFM check, here is what I see:
1. DRC Error: Unplated multi-layer pad(s) detected
2. DFM error from 4PCB: Insufficient Inner Spacing.
I am trying to understand where and how to fix this issue? Can someone please advise?
tarun172
Thanks & Regards,
Tarun S
Offline thm_w
  • Non-expert
Re: Non Plated Through Hole Settings
« Reply #1 on: March 13, 2023, 09:50:29 pm »
Are these are 4PCB errors or Altium errors?
It seems like they support both so simply having unplated is not the issue: https://www.4pcb.com/pcb-manufacturing-custom-standard.html
Maybe you can post the pad properties you've chosen: https://www.altium.com/documentation/altium-designer/pcb-pad-properties?version=19.0
Simple pad stack or top middle bottom?
Offline tooki
« Reply #2 on: May 06, 2023, 03:01:51 pm »
Hi all,
I just ran into this a month ago.
It’s not an error, just a warning, and it’s hard-coded and cannot be disabled. Just ignore it.
FYI, the Altium support forums aren’t searched by Google. Log into the Altium website and then search there. That’s the only place I found the answer.
