Author Topic: pcb auto annotation. Altium designer 15.0  (Read 11019 times)
Offline georpoTopic starter
  • Country: gr
« on: February 16, 2024, 03:22:26 pm »
Hello everyone!
I am in the middle of a big pcb design without schematic and I have named all capacitors "C?" , all resistors "R?", all ICs "U?"  etc.
Is there a way for Altium to assign designators automatically? C1,C2 R1,R2 etc.
Thanks for any ideas.
Offline thm_w
  • Non-expert
Re: pcb auto annotation. Altium designer 15.0
« Reply #1 on: February 16, 2024, 09:33:38 pm »
Offline PlainName
  • Country: va
« Reply #2 on: February 16, 2024, 10:11:35 pm »
Don't have AD15 to check, but from the Tools menu there could well be a "Re-Annotate..." menu item which will probably do the biz for you.
Offline Batang
  • Country: my
« Reply #3 on: February 17, 2024, 01:46:55 am »
"a big pcb design without schematic"
Why!!
  • Country: gr
« Reply #4 on: February 17, 2024, 01:58:47 pm »
hello and thanks for all replies.
It does not matter how I got here.
without schematic, is there a way to have altium change all the C? to C1,C2 etc
Offline PlainName
  • Country: va
« Reply #5 on: February 17, 2024, 03:23:27 pm »
As I posted earlier, use the Re-Annotate menu item from the Tools menu (screeny from AD13 attached).
  • Country: gr
« Reply #6 on: February 17, 2024, 03:51:28 pm »
re-annotate changed ALL designators to "1"
I already tried this before asking.
Offline PlainName
  • Country: va
« Reply #7 on: February 17, 2024, 04:02:20 pm »
OK. It would be useful for you to mention that at the start, although I don't know why it doesn't number them sequentially.
Edit: Just tried this with a plain PCB which isn't in a project and has no schematic. None of the components had the ? number (that is, they were already C1, C2, etc. I chose ascending x then ascending y, then all the various combinations and even 'use board position'. Every time the component designators were changed appropriately.
You might try click a component, then right click and select 'same as' using only 'component' as the match. That will select all components. Then run the re-annotate and see if that helps. If not then your board is borked or your designators aren't actual designators, or something similar.
« Last Edit: February 17, 2024, 04:13:20 pm by PlainName »
