Author Topic: Lost all my PCB footprints?  (Read 1891 times)
Offline WillHuangTopic starter
« on: June 06, 2016, 04:33:14 am »
I was working on Altium and then all of a sudden my computer crashed and had to reboot. When I re-opened my project, I had to modify a component footprint that I created. When I opened the PCB library panel, all of my footprints are gone! When I view my PCB, I can still see my footprints and 3D models on the board, but all the footprints in the library somehow dissapeared....
Does anybody know a fix?
EDIT:
Nevermind, I managed to get it back by searching through the History folder!
« Last Edit: June 06, 2016, 04:42:04 am by WillHuang »
Offline dansku
  • I make things
    • Personal Blog
Re: Lost all my PCB footprints?
« Reply #1 on: August 09, 2016, 10:06:56 am »
Glad you managed to find the solution.
 Just remember to backups your stuff. Most of my projects I use the SVN version control.
Remember to backup your stuff. What would happen to your projects if your computer explode? (aka stolen, burned, went to mars...)  :scared:
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: August 09, 2016, 10:30:26 am »
Step 0. Do you have automatic backups turned on?  (Tools/Preferences, Data Management, Backup, Auto save.  Note the path; change it to a more convenient place if you like.)
Step 1. Check the backups.  If you see a file, of the same name but with ".~(1)" numbers added on, with a newer "Modified" date, open it.
Step 2. Check that the file still looks right and all, then when you're satisfied, save it over the original project file.
Seven Transistor Labs, LLC
The following users thanked this post: dansku
