Author Topic: Create list for connections between Nets & Ports?  (Read 1729 times)
Offline ANTALIFETopic starter
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« on: April 29, 2016, 06:31:19 am »
Hello
Is it possible to make (or extract) a list which shows what Nets are connected to which Ports?
I know you can make a list of all the Nets and which component they go to, but I just want to make sure that all my Nets go to the correct Ports between schematics.
Cheers
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Create list for connections between Nets & Ports?
« Reply #1 on: May 02, 2016, 12:05:16 am »
Found a hackish way of doing it, just generate the Verilog file with the "Generate multiple Verilog files" option ticked to get connections for all schematics.
Then you can just either read the files in notepad or import them into a spreadsheet.
