Author Topic: Importing multiple Altium 3D PCB exports into a single Solidworks project  (Read 2577 times)
Offline tesla500Topic starter
I've been having problems when trying to import multiple Altium 3D STEP exports into Solidworks. Different board would have components of the same name resulting in the wrong 3D models being used. Finally figured out how to get around this! Thought I'd throw this here so others can benefit.
http://omeganaught.com/2015/03/importing-multiple-altium-3d-pcb-exports-into-a-single-solidworks-project/
Offline daedalus
hi, to fix this, open a single board step file in solidworks. With the assembly open, use file->pack and go, then set the save to folder to someplace else, check add prefix, and set the prefix to board1. Click save.
This should turn parts called C1,C2,C3 into board1C1, board1C2, board1C3.
You then need to open the exported assembly and use it in your top level design.
You have to repeat this for each board.
