Author Topic: Electrical object hotspot snap in AD16.1, schematic.  (Read 2092 times)
Offline FortranTopic starter
« on: June 16, 2018, 05:33:39 am »
Hi.
I used to be able to bring two pins close to each other and they would snap together, like two resistors that are slightly off-grid.
But ever since I reinstalled my machine, this feature is eluding me.
Any ideas?
All work and no snap make Fortran cry.
Online T3sl4co1l
    • Seven Transistor Labs
Re: Electrical object hotspot snap in AD16.1, schematic.
« Reply #1 on: June 16, 2018, 08:45:47 am »
Hit the "Snap" button in the bottom right corner.  There's also some key shortcuts and menu options that control this behavior.  Likely you accidentally hit SHIFT+S or something. :P
Seven Transistor Labs, LLC
« Reply #2 on: June 16, 2018, 10:00:54 am »
Yeah I'm pretty sure I've either hit something by mistake, or forgot to set something after installing.  :-//
There is no "Snap" button in the lower right corner.   Only [System][Design Compiler][SCH][Instruments][Shortcuts]
Online T3sl4co1l
« Reply #3 on: June 16, 2018, 02:02:44 pm »
Oh right, SCH...
D, O, Sheet Options tab, Grids, turn on snap.
« Reply #4 on: July 06, 2018, 04:43:38 am »
Today I finally found what setting was wrong.  :-+
Schematic Preferences / Graphical Editing / Always Drag
Somehow Electrical Hotspots gets all wonky if this is on.
Online T3sl4co1l
« Reply #5 on: July 06, 2018, 12:13:17 pm »
Huh, I never noticed that before.  Do you use grid 1 (or, god forbid, no grid at all) a lot??
I suppose my workflow is: 1. place components roughly, then wire them (Place/Wire snaps to pins); 2. snap objects to, and drag components with, large (10) grid, so nothing comes apart; drag makes it obvious which wires are connected to pins, so a mere click (well, a long click, a drag, okay?..) verifies connectivity.
10 grid on schematic is only practical if the symbol pins are aligned to it as well.
Shudder, off-grid pins... I've only seen it a few times, and only once not bothered to clean it up... now I feel dirty...
« Reply #6 on: July 07, 2018, 06:47:15 am »
Uh. I don't know really. I'm mostly using the default grids.
Nothing custom in schematic or component editor.
Still get a lot of offgrid pins for some reason.
But now it works like I'm used to so I'm not really bothered by it. I use ctrl to drag.
