Author Topic: Hotkeys to view configurations  (Read 2914 times)
Offline poorchavaTopic starter
  • Troll Cave Electronics!
« on: October 25, 2013, 05:21:17 am »
Is there a way to set hotkeys to view configurations? I have about 6 different view configurations I use frequently, but switching by L-click_on_list-enter seems time consuming.
Can this be done with configurable keyboards like those manufactured by Preh for example? If so, then how does that work? Is there some sort of hidden api or driver for Altium/Preh combination, or does the keyboard only generate key strokes (in which case I'd also have to assign some hotkeys to view configurations)
Offline jamiechi
Re: Hotkeys to view configurations
« Reply #1 on: November 16, 2013, 12:07:25 am »
Try this. http://www.autohotkey.com/
Autohotkeys should do what you want.
Offline WernerT
« Reply #2 on: November 28, 2013, 09:10:47 pm »
Maybe this helps:
To create a shortcut
1. right click on main toolbar (just underneath menu bar)
2. click on "Customize..."
3. in the tab "Commands" (normally allready open), click on the tab "NEW" at the bottom
4. in the 'Action' plane after "Process", click "Browse" and find and select anything usable
5. in the 'Action' plane after "Parameters" click on the dropdown and select anything usable
6. in the 'Shortcuts' plane, click in the region after 'Primary', and type the key, or combination you want to as shortcut
Done!!
